trans not shifting
Old Feb 14, 2009 | 08:42 AM
foreman500's Avatar
Default trans not shifting
I have a 1999 Jetta,2.0L.Trans not shifting,check for codes,has a code PO722.Output speed signal.I changed the sensor and still not working.Checked all wiring to TCM and all ok.Anybody have any suggestions?
Old Feb 14, 2009 | 10:05 AM
racerx002's Avatar
Default RE: trans not shifting
P0772 - Shift solenoid E circuit stuck on. See if it is staying on all the time now that you've replaced it.
Old Feb 14, 2009 | 05:57 PM
foreman500's Avatar
The code was PO722.And how do i theck to see if solenoid E is stuck on?
Old Feb 14, 2009 | 09:18 PM
racerx002's Avatar
With a multimeter or test light.
Old Feb 14, 2009 | 09:59 PM
foreman500's Avatar
where do i check this at?
Old Feb 15, 2009 | 08:44 AM
racerx002's Avatar
At the harness that plugs into the solenoid.
Jan 17, 2011 02:00 AM
chunks3141
Apr 12, 2009 11:07 AM
Bensdad
Mar 4, 2009 06:49 PM
jquinonez
Feb 11, 2009 07:13 PM
jodievw
Oct 7, 2006 04:47 PM
