trans not shifting
I have a 1999 Jetta,2.0L.Trans not shifting,check for codes,has a code PO722.Output speed signal.I changed the sensor and still not working.Checked all wiring to TCM and all ok.Anybody have any suggestions?
RE: trans not shifting
P0772 - Shift solenoid E circuit stuck on. See if it is staying on all the time now that you've replaced it.
The code was PO722.And how do i theck to see if solenoid E is stuck on?
With a multimeter or test light.
where do i check this at?
At the harness that plugs into the solenoid.
