Sunroof drain - Yep... this thread again
Old Nov 5, 2012 | 12:59 PM
Luieburger's Avatar
Default Sunroof drain - Yep... this thread again
Hello all,
I encountered the wet passenger floor. Read all the ways to fix the problem, tested my front right drain and found that it was blocked. I cleared the block, but in the process I removed the nipple from the frame, which pulled the hose out from the back of the nipple.
What's the best way to get in the back and line that hose up with the back of the nipple? I've tried using a wire to line it up. It sorta works but water still leaks down the inside of the frame. I feel like the hose is mostly line up, but not optimally placed to catch all of the water.
Any suggestions for how to get that lined up? I really need access to the back of that space.
Thanks!
Old Nov 5, 2012 | 01:43 PM
Old Nov 5, 2012 | 02:07 PM
Luieburger's Avatar
Yes I've read through those threads already. My problem is no longer a blockage. My problem is getting the drain hose lined up with the nipple. I'm trying to get the existing tube re-aligned. I'm not putting in a new tube unless I determine that the current tube is cut somewhere.
jpneilsonUSCG21
May 19, 2011 11:08 PM
medman
May 22, 2009 08:57 AM
jbag
Jan 21, 2008 08:09 AM
frontier2005
Apr 16, 2007 01:07 PM
lwaters46506
Sep 25, 2006 10:07 PM
