starting problem
Old Jan 6, 2009 | 06:31 PM
roxsgirl's Avatar
Member
Default starting problem
so recently ive noticed im having a starting issue on a constant irregular basis (if that makes sense). its not all the time but maybe twice a week at the most when i go to start my car...as soon as it starts it turns off. when i go to turn it on again 90% of the time it will start up but the other 10% of the time it will fail again. i just want to say its something like the starter...but ive never had starter problems with any of my other cars so i dont know what the signs of a failing starter would be. anyone have any clue?! thanks! )
Old Jan 6, 2009 | 06:40 PM
roxsgirl's Avatar
Member
Default RE: starting problem
also let me add...there is no clunking noise when i turn the key...and sometimes i have also noticed the lights dim but then go back to bright...so haha...now this is sounding more like a battery issue?! oh boy...thanks for hanging in with my while i learn more about my car! )
doubleroost's Avatar
I had a very similar problem to that, my battery terminals were loose and when i tightened them down it seemed to do it less often.
Old Jan 6, 2009 | 08:19 PM
PassatGuy's Avatar
If it fails when the wheather is moist, you may want to check the coil for cracks
Old Jan 7, 2009 | 08:14 AM
racerx002's Avatar
You need a new battery.
Old Jan 7, 2009 | 11:32 AM
roxsgirl's Avatar
Member
well im liking the fact that my problem isnt such an expensive one...but yeah it does seem to fail only in the colder moist weather. how do i check my coils and where exactly am i looking for those?!
Old Jan 7, 2009 | 12:57 PM
  #7
racerx002's Avatar
Your ignition coil is where all the spark plug wires are grouped together andlead to the spark plugs. You just pull off the boots and check the terminals for cracks. If there aren't any get your battery tested.
Old Jan 8, 2009 | 10:08 AM
  #8
dabatman99's Avatar
Perhaps its just a bad connection on the battery, or a bad ignition switch. When you try to start it and it doesn't turn over, slightly turn the key either forward or backwards and see if the starter takes off. Those switches are finicky and will sometimes do that.
bacustoms420
Oct 8, 2016 03:57 AM
shirike
Jul 5, 2007 03:53 AM
Duke
Jan 24, 2007 12:09 PM
Jugomiki
Dec 31, 2006 06:40 PM
xlaurax36
Jun 15, 2006 08:52 PM
