po722 speed sensor & po730 gear ratio ?? after i pressure washed my engine,
what is the quick fix or the sulution to my problem? i pressure washed my 02 jetta wagon engine yesterday and when i went to drive away the tranny would not shift right, if i kick the throttle after 30 mph it shifts... now today i let the car run for a while with the hope that some thing will dry off and all set , not the case. I have no clue where or what the speed sensor looks like or is located? any pic's? and solutions please???
Welcome to the forum even though you've been here over 12 months and only made 2 posts.
VAG Error Code: 00297
EOBD II Error Code: P0722
VAG Error Code: 00652
Fault Location:
Output shaft speed (OSS) sensor (G38) - no signal
Possible Cause:
Malfunction indicator lamp (MIL) Triggered on first occurrence.
Wiring.
Vehicle speed (VSS) sensor.
Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM).
Wiring.
EOBD II Error Code: P0730
Fault Location:
Transmission Shift-Range Controller - Incorrect gear ratio
Possible Cause:
Wiring.
Transmission range (TR) sensor/switch.
Shift solenoids (SS).
Transmission mechanical fault.
Wiring.
As taken from my Free EODB II Error Codes Software
Hi , yes it has been a while, that i recall i had to change the speed sensor. nothing else i could have done to fix it i was told. small item and you can do it your self. I had my mechanic do it but looking at the job, i should have done it my self...
Feb 26, 2011 12:52 AM
