po722 speed sensor & po730 gear ratio ?? after i pressure washed my engine,
what is the quick fix or the sulution to my problem? i pressure washed my 02 jetta wagon engine yesterday and when i went to drive away the tranny would not shift right, if i kick the throttle after 30 mph it shifts... now today i let the car run for a while with the hope that some thing will dry off and all set , not the case. I have no clue where or what the speed sensor looks like or is located? any pic's? and solutions please??? :confused:
1 Attachment(s)
Welcome to the forum even though you've been here over 12 months and only made 2 posts. Attachment 3330
VAG Error Code: 00297 EOBD II Error Code: P0722 Fault Location: Output shaft speed (OSS) sensor (G38) - no signal Possible Cause: Malfunction indicator lamp (MIL) Triggered on first occurrence. Wiring. Vehicle speed (VSS) sensor. Engine control module (ECM)/Powertrain control module (PCM)/Transmission control module (TCM). VAG Error Code: 00652 EOBD II Error Code: P0730 Fault Location: Transmission Shift-Range Controller - Incorrect gear ratio Possible Cause: Wiring. Transmission range (TR) sensor/switch. Shift solenoids (SS). Transmission mechanical fault. As taken from my Free EODB II Error Codes Software |
Originally Posted by maya2.0
(Post 40359)
Originally Posted by JediMan
(Post 58091)
Hi...I know it's been a while since you posted, but I'm having the exact same problem. Did this issue resolve on its own (how long did it take) or what steps did you take to correct the problem? Thanks!
