oil in the air filter
Old Aug 26, 2007 | 02:00 PM
beebop13's Avatar
Default oil in the air filter
I was recently checking things under my hood. I took a look at the air filter and there was oil in it and oil in the tube leading to the filter. I am a newer volkswagen ownerbut I know thatin other carsoil in the air filterwould not be a good sign. Is this a normal vw thing?
-Thanks
Old Aug 26, 2007 | 08:37 PM
joenewton07's Avatar
Default RE: oil in the air filter
what trans/engine is in the car? are you running it hard at all? sounds like youre running it hard and the the pcv system is sending oil into the air filter...you may want to think about getting a catch can now...
Old Aug 26, 2007 | 09:16 PM
beebop13's Avatar
well it is a 2.0 automatic and I just got it about a week ago. I try not to run it hard because I am very gas conscience. Could the pcv need to be replaced?
Old Aug 27, 2007 | 04:47 PM
quite possibly, but im not sure in the 2.0. try searching on www.vwvortex.com thats where i would start. do you have any codes? check engine light on?
chrissy1984
Mar 2, 2007 02:25 AM
chrissy1984
Feb 26, 2007 10:25 PM
robsob
Jan 1, 2007 09:04 PM
saltydogs
Sep 11, 2006 03:17 PM
trafly
Dec 26, 2005 11:09 PM
