no power to injectors 2005 MKIV 2.0 BEV
Old Dec 7, 2015 | 08:34 PM
endkarter's Avatar
Default no power to injectors 2005 MKIV 2.0 BEV
injector fuse #32 has no power. Have changed fuel pump relay and pump. VAG shows P0201 thru P0204 injector circuit malfuntion only. Help!
Old Dec 8, 2015 | 08:59 AM
VAG Error Code: 16585
EOBD II Error Code: P0201
Fault Location:
Injector 1 (N30) - Circuit Malfunction/Open Circuit
Possible Cause:
Lack/Loss of Power.
The engine may be harder to start.
Engine hesitation.
Wiring/Connector(s).
Injector 1 (N30).
Engine Control Module (ECM).
Possible Solutions:
Low side signal current < 2.1 A.
When is the code detected?:
The P0201 is set if the Engine Control Module (ECM) is detects a low or high voltage drop or resistance at the injector 1.
Description:
Engine Control Module (ECM) checks the injectors circuit resistance and monitors the voltage drop during normal operation. The Engine Control Module (ECM) will trigger the P0201 code when the resistance or voltage drop at the injector 1 is out of specifications.
EOBD II Error Code: P0204
Fault Location:
Injector 4 (N33) - Circuit Malfunction/Open Circuit
Possible Cause:
Lack/Loss of Power.
Engine hesitation.
Injector 4 (N33).
Possible Solutions:
The P0204 is set if the Engine Control Module (ECM) is detects a low or high voltage drop or resistance at the injector 4.
Description:
Engine Control Module (ECM) checks the injectors circuit resistance and monitors the voltage drop during normal operation. The Engine Control Module (ECM) will trigger the P0204 code when the resistance or voltage drop at the injector 4 is out of specifications.
Haze89
Feb 18, 2010 06:48 PM
singletrack12
Dec 18, 2008 10:58 PM
markkk1965
May 3, 2007 03:39 PM
libertyh
Apr 27, 2007 02:47 AM
VWnewbie
Mar 17, 2007 11:40 AM
