Need Tech Help!!!!!
Old Aug 19, 2006 | 08:24 PM
VRsick's Avatar
Default Need Tech Help!!!!!
Hey guys,
Im having a serious issue, The other day I was driving and the car just went dead. I had it towed home and found that the sparkplug wires were arcing. i changed them as well as the plugs. Now the car will start and then go dead. It wont idle at all just keeps starting it will stay at like 250 rpm for like one min then die. I have no idea what to do I changed the fuel filter and it still seems that its not getting fuel but there was some in the filter. Any suggetions I was thinking maybe the Pump is gone but I have no Idea. And also on the top of the engine there is a lil valve I need to know what the exact name for that is. Its looks like maybe some kind of vacum valve has 3 hoses conected to it 2 big one small any help is great thanks. I know Im a noob but I need help!!!!!
Old Aug 19, 2006 | 10:55 PM
bagel's Avatar
Default RE: Need Tech Help!!!!!
My guess, and I mean guess, would be some sort of timing belt or coil pack. It just sounds to me like the spark isn't doin much. Maybe someone else can help more than me...sorry.
Old Aug 24, 2006 | 07:56 PM
emagdnim's Avatar
yeah, all you need to have a running engine is air, fuel, and spark (basically)... sounds like you've eliminated fuel as a suspect, i would look into spark...
i agree with bagel, it kinda sounds like a coil pack, are all the cylinders firing? if not, check the wires and if its not them its most likely the coil pack...
is your air filter clean? i doubt that it would be dirty enough to stall your car, but check it out
-Ben
vwcorradog60
Jan 21, 2021 01:49 PM
May 27, 2012 08:45 AM
yc2010
Oct 19, 2010 09:49 PM
Kylerob
Dec 26, 2007 03:28 PM
VW_AT
Jul 23, 2007 12:09 PM
