need info on mkVI Jetta transmission
Old Mar 17, 2017 | 04:28 PM
Tkoontz89's Avatar
Default need info on mkVI Jetta transmission
I own a 2013 Jetta s with the 2.5l inline 5 and a 5 speed manual transmission. It has 63000 miles and two weeks ago 2nd and 5th gear went out. Cannot get either to engage. All other gears are fine and shift in and out of gear normally. Took it to a VW dealer and they are telling me it is a clucth issue and not internal on transmission. Wondering if anyone else has run into this problem before.
Old Mar 19, 2017 | 08:53 AM
First job is bleed the clutch hydraulics.
There are loads of gearbox codes you need to find yours?
https://volkswagenforum.com/forum/ge...sticker-35079/
Manufacturer: VW, Date(s) Used: 06/2010-06/2015, Model: Jetta, Transmission Code: LDZ, Transmission Type: 5S
Post moved to correct section.
Gewing4
Dec 16, 2011 03:21 PM
PhanTim720
Dec 14, 2009 08:24 AM
dennis01
Aug 7, 2008 03:32 AM
nmetz2007
Jan 6, 2007 09:25 PM
