Misfire help
Old Jun 9, 2013 | 08:21 PM
tgol6622's Avatar
Default Misfire help
VCDS-Lite Version: Release 1.1
Friday, 08 March 2013, 11:45:15:56530
Control Module Part Number: 06A 906 032 PE
Component and/or Version: 2.0l R4/2V G 5229
Software Coding: 00001
Work Shop Code: WSC 00066
VCID: 70938F1123AD
Additional Info: 3VWRA69M84M018808 VWZ7Z0C7981361
13 Faults Found:
17763 - Cylinder 1 Ignition Circuit: Open Circuit
P1355 - 35-00 - -
17769 - Cylinder 3 Ignition Circuit: Open Circuit
P1361 - 35-00 - -
17772 - Cylinder 4 Ignition Circuit: Open Circuit
P1364 - 35-00 - -
17766 - Cylinder 2 Ignition Circuit: Open Circuit
P1358 - 35-00 - -
16648 - Fuel Injector #2 (N31): Short to Ground
P0264 - 35-10 - - - Intermittent
17833 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-10 - - - Intermittent
16645 - Fuel Injector #1 (N30): Short to Ground
P0261 - 35-10 - - - Intermittent
16654 - Fuel Injector #4 (N33): Short to Ground
P0270 - 35-10 - - - Intermittent
16651 - Fuel Injector #3 (N32): Short to Ground
P0267 - 35-10 - - - Intermittent
17880 - EVAP Leak Detection Pump: Short to Ground
P1472 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-00 - -
16687 - Cylinder 3: Misfire Detected
P0303 - 35-00 - -
16686 - Cylinder 2: Misfire Detected
P0302 - 35-00 - -
This happens with new plugs, wires, injectors and coilpack.
Old Jun 10, 2013 | 07:36 AM
Check compressions.
VAG Error Code: 17763
EOBD II Error Code: P1355
Fault Location:
Ignition Coil/Amplifier, Cylinder 1 - Open Circuit
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) ON.
Misfire.
No Spark.
Faulty Ignition coil(s) with output stage.
Fuse(s) faulty.
Wiring and/or Connector(s) from coil(s) to Engine Control Module (ECM) faulty.
Possible Solutions:
Check/Replace Coil(s).
Check Fuse(s).
Check Wiring and/or Connector(s).
Special Notes:
When found in the NAR (North American Region) VW Golf/Jetta/Bora (1J/9M) platform equipped with a 2.0L check TSB # 01-08-27 or 2010575.
VAG Error Code: 17769
EOBD II Error Code: P1361
Fault Location:
Ignition Coil/Amplifier, Cylinder 3 - Open Circuit
Possible Cause:
Misfire.
No Spark.
Fuse(s) faulty.
Possible Solutions:
Check Fuse(s).
Special Notes:
VAG Error Code: 17772
EOBD II Error Code: P1364
Fault Location:
Ignition Coil/Amplifier, Cylinder 4 - Open Circuit
Possible Cause:
Misfire.
No Spark.
Fuse(s) faulty.
Possible Solutions:
Check Fuse(s).
Special Notes:
VAG Error Code: 17766
EOBD II Error Code: P1358
Fault Location:
Ignition Coil/Amplifier, Cylinder 2 - Open Circuit
Possible Cause:
Misfire.
No Spark.
Fuse(s) faulty.
Possible Solutions:
Check Fuse(s).
Special Notes:
VAG Error Code: 16648
EOBD II Error Code: P0264
Fault Location:
Injector 2 (N31) - Circuit Low
Possible Cause:
Wiring short to earth.
Injector.
Engine Control Module (ECM).
VAG Error Code: 16645
EOBD II Error Code: P0261
Fault Location:
Injector 1 (N30) - Circuit Low
Possible Cause:
Injector.
VAG Error Code: 16654
EOBD II Error Code: P0270
Fault Location:
Injector 4 (N33) - Circuit Low
Possible Cause:
Injector.
VAG Error Code: 16651
EOBD II Error Code: P0267
Fault Location:
Injector 3 (N32) - Circuit Low
Possible Cause:
Injector.
VAG Error Code: 17833
EOBD II Error Code: P1425
Fault Location:
Evaporative Emission (EVAP) Canister Purge Valve (N80) - Short Circuit to Earth
Possible Cause:
Malfunction Indicator Lamp (MIL)(K83) Triggered on first occurrence.
Evaporative emission (EVAP) canister purge valve (N80).
VAG Error Code: 17880
EOBD II Error Code: P1472
Fault Location:
Evaporative Emission (EVAP) Leak Detection Pump - Short Circuit to Earth
Possible Cause:
Evaporative emission (EVAP) leak detection pump.
VAG Error Code: 16684
EOBD II Error Code: P0300
Fault Location:
Random/Multiple Cylinder(s) - Misfire Detected
Possible Cause:
Air Intake System leaking.
Fuel Supply faulty.
Injector(s) faulty.
Ignition coil(s).Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open.
Camshaft Position Sensor (G40) faulty.
Low compression.
Wiring.
Possible Solutions:
Check Misfire Recognition.
Check Air Intake System.
Check Fuel Supply.
Check Ignition Coil(s).
Check Camshaft Position Sensor (G40).
Special Notes:
This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder.
VAG Error Code: 16687
EOBD II Error Code: P0303
Fault Location:
Cylinder 3 - Misfire Detected
Possible Cause:
Wiring.
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Special Notes:
VAG Error Code: 16686
EOBD II Error Code: P0302
Fault Location:
Cylinder 2 - Misfire Detected
Possible Cause:
Wiring.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Special Notes:
Old Jun 12, 2013 | 05:08 AM
tgol6622's Avatar
Keithuk-
Yeah, I did compression tests and all the cylinders roughly tested at the mid 130's PSI. Thanks. How do I do a PM on this site?
T-Rex
Old Jun 12, 2013 | 06:18 AM
You click on a username and select Send a private message to.... or goto their Public Profile and send one from Contact Info.
Old Jun 13, 2013 | 08:07 AM
tgol6622's Avatar
None of those options worked for me.
Old Jun 13, 2013 | 07:50 PM
Well I've just sent you a PM so it works for me.
Who do you want to PM me?
Unless thats because you've only made 3 post, some forum make you to make 10 posts before certain options are available.
Old Jun 14, 2013 | 08:18 AM
  #7
tgol6622's Avatar
I bet your right. Soon I will get 10 posts and we will see. It won't even let me respond to the PM you sent me.
Old Jun 14, 2013 | 07:45 PM
  #8
Well I sent you a PM if you wanted to PM me then just try and reply to it.
Old Jun 17, 2013 | 11:42 PM
  #9
tgol6622's Avatar
It won't let me. What's the deal with your EOBD II Fault Codes Software?
Old Jun 22, 2013 | 07:39 PM
  #10
I've just sent you a PM with all the details.
