Misfire help
VCDS-Lite Version: Release 1.1
Friday, 08 March 2013, 11:45:15:56530 Control Module Part Number: 06A 906 032 PE Component and/or Version: 2.0l R4/2V G 5229 Software Coding: 00001 Work Shop Code: WSC 00066 VCID: 70938F1123AD Additional Info: 3VWRA69M84M018808 VWZ7Z0C7981361 13 Faults Found: 17763 - Cylinder 1 Ignition Circuit: Open Circuit P1355 - 35-00 - - 17769 - Cylinder 3 Ignition Circuit: Open Circuit P1361 - 35-00 - - 17772 - Cylinder 4 Ignition Circuit: Open Circuit P1364 - 35-00 - - 17766 - Cylinder 2 Ignition Circuit: Open Circuit P1358 - 35-00 - - 16648 - Fuel Injector #2 (N31): Short to Ground P0264 - 35-10 - - - Intermittent 17833 - EVAP Purge Valve (N80): Short to Ground P1425 - 35-10 - - - Intermittent 16645 - Fuel Injector #1 (N30): Short to Ground P0261 - 35-10 - - - Intermittent 16654 - Fuel Injector #4 (N33): Short to Ground P0270 - 35-10 - - - Intermittent 16651 - Fuel Injector #3 (N32): Short to Ground P0267 - 35-10 - - - Intermittent 17880 - EVAP Leak Detection Pump: Short to Ground P1472 - 35-10 - - - Intermittent 16684 - Random/Multiple Cylinder Misfire Detected P0300 - 35-00 - - 16687 - Cylinder 3: Misfire Detected P0303 - 35-00 - - 16686 - Cylinder 2: Misfire Detected P0302 - 35-00 - - This happens with new plugs, wires, injectors and coilpack. |
1 Attachment(s)
Welcome to the forum. Attachment 2795
Check compressions. VAG Error Code: 17763 EOBD II Error Code: P1355 Fault Location: Ignition Coil/Amplifier, Cylinder 1 - Open Circuit Possible Cause: Malfunction Indicator Lamp (MIL)(K83) ON. Misfire. No Spark. Faulty Ignition coil(s) with output stage. Fuse(s) faulty. Wiring and/or Connector(s) from coil(s) to Engine Control Module (ECM) faulty. Possible Solutions: Check/Replace Coil(s). Check Fuse(s). Check Wiring and/or Connector(s). Special Notes: When found in the NAR (North American Region) VW Golf/Jetta/Bora (1J/9M) platform equipped with a 2.0L check TSB # 01-08-27 or 2010575. VAG Error Code: 17769 EOBD II Error Code: P1361 Fault Location: Ignition Coil/Amplifier, Cylinder 3 - Open Circuit Possible Cause: Malfunction Indicator Lamp (MIL)(K83) ON. Misfire. No Spark. Faulty Ignition coil(s) with output stage. Fuse(s) faulty. Wiring and/or Connector(s) from coil(s) to Engine Control Module (ECM) faulty. Possible Solutions: Check/Replace Coil(s). Check Fuse(s). Check Wiring and/or Connector(s). Special Notes: When found in the NAR (North American Region) VW Golf/Jetta/Bora (1J/9M) platform equipped with a 2.0L check TSB # 01-08-27 or 2010575. VAG Error Code: 17772 EOBD II Error Code: P1364 Fault Location: Ignition Coil/Amplifier, Cylinder 4 - Open Circuit Possible Cause: Malfunction Indicator Lamp (MIL)(K83) ON. Misfire. No Spark. Faulty Ignition coil(s) with output stage. Fuse(s) faulty. Wiring and/or Connector(s) from coil(s) to Engine Control Module (ECM) faulty. Possible Solutions: Check/Replace Coil(s). Check Fuse(s). Check Wiring and/or Connector(s). Special Notes: When found in the NAR (North American Region) VW Golf/Jetta/Bora (1J/9M) platform equipped with a 2.0L check TSB # 01-08-27 or 2010575. VAG Error Code: 17766 EOBD II Error Code: P1358 Fault Location: Ignition Coil/Amplifier, Cylinder 2 - Open Circuit Possible Cause: Malfunction Indicator Lamp (MIL)(K83) ON. Misfire. No Spark. Faulty Ignition coil(s) with output stage. Fuse(s) faulty. Wiring and/or Connector(s) from coil(s) to Engine Control Module (ECM) faulty. Possible Solutions: Check/Replace Coil(s). Check Fuse(s). Check Wiring and/or Connector(s). Special Notes: When found in the NAR (North American Region) VW Golf/Jetta/Bora (1J/9M) platform equipped with a 2.0L check TSB # 01-08-27 or 2010575. VAG Error Code: 16648 EOBD II Error Code: P0264 Fault Location: Injector 2 (N31) - Circuit Low Possible Cause: Wiring short to earth. Injector. Engine Control Module (ECM). VAG Error Code: 16645 EOBD II Error Code: P0261 Fault Location: Injector 1 (N30) - Circuit Low Possible Cause: Wiring short to earth. Injector. Engine Control Module (ECM). VAG Error Code: 16654 EOBD II Error Code: P0270 Fault Location: Injector 4 (N33) - Circuit Low Possible Cause: Wiring short to earth. Injector. Engine Control Module (ECM). VAG Error Code: 16651 EOBD II Error Code: P0267 Fault Location: Injector 3 (N32) - Circuit Low Possible Cause: Wiring short to earth. Injector. Engine Control Module (ECM). VAG Error Code: 17833 EOBD II Error Code: P1425 Fault Location: Evaporative Emission (EVAP) Canister Purge Valve (N80) - Short Circuit to Earth Possible Cause: Malfunction Indicator Lamp (MIL)(K83) Triggered on first occurrence. Wiring short to earth. Evaporative emission (EVAP) canister purge valve (N80). VAG Error Code: 17880 EOBD II Error Code: P1472 Fault Location: Evaporative Emission (EVAP) Leak Detection Pump - Short Circuit to Earth Possible Cause: Wiring short to earth. Evaporative emission (EVAP) leak detection pump. VAG Error Code: 16684 EOBD II Error Code: P0300 Fault Location: Random/Multiple Cylinder(s) - Misfire Detected Possible Cause: Air Intake System leaking. Fuel Supply faulty. Injector(s) faulty. Ignition Cable(s) and/or Spark Plug(s) faulty. Ignition coil(s).Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open. Camshaft Position Sensor (G40) faulty. Low compression. Wiring. Possible Solutions: Check Misfire Recognition. Check Air Intake System. Check Fuel Supply. Check Injector(s) and Injector Sealing. Check Ignition Cable(s) and Spark Plug(s). Check Ignition Coil(s). Check Exhaust Gas Recirculation (EGR) Valve (N18). Check Camshaft Position Sensor (G40). Special Notes: This DTC indicates that one or multiple cylinders are misfiring, but the ECU fails to identify the cylinder. VAG Error Code: 16687 EOBD II Error Code: P0303 Fault Location: Cylinder 3 - Misfire Detected Possible Cause: Wiring. Ignition system. Fuel injectors. Fuel pressure. Running out of fuel. EVAP canister purge valve. Evaporative emission system. Low compression. Base engine problems. Engine Control Module (ECM). Special Notes: This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression. VAG Error Code: 16686 EOBD II Error Code: P0302 Fault Location: Cylinder 2 - Misfire Detected Possible Cause: Wiring. Ignition system. Fuel injectors. Fuel pressure. Running out of fuel. EVAP canister purge valve. Evaporative emission system. Low compression. Base engine problems. Engine Control Module (ECM). Special Notes: This feature search for engine misfire in a specific cylinder. Most of the time the cause for a misfire is a lack of combustion in a cylinder due to absence of spark, poor fuel metering, or poor compression. As taken from my https://volkswagenforum.com/forum/ge...oftware-34973/ |
Keithuk-
Yeah, I did compression tests and all the cylinders roughly tested at the mid 130's PSI. Thanks. How do I do a PM on this site? T-Rex |
You click on a username and select Send a private message to.... or goto their Public Profile and send one from Contact Info.
Originally Posted by Keithuk
(Post 60399)
Well I've just sent you a PM so it works for me.
Who do you want to PM me? Unless thats because you've only made 3 post, some forum make you to make 10 posts before certain options are available. |
(Post 60405)
Well I sent you a PM if you wanted to PM me then just try and reply to it.
It won't let me. What's the deal with your EOBD II Fault Codes Software?
I've just sent you a PM with all the details.
