low power
Hi, I`m new in the forum and I have a Jetta 2.0L of the 2001
My VW have a problem
, it doesn`t have any power after the first start of the day (in the morning), or when it has been more than 5 hours turned off. The car had the DTC p1128, p0131 and misfire codes.
I changed the lambda sensor and the p0131 disapeared, also I changed the AFM and the p1128 is out too, I erased the misfire codes and they never come back, but the problem is still present
. The problem is like lean mixture.
After 2 or 3 minutes the car improves a little and I can drive it normally.
The fuel pressure is normal when the car fails, fuel injectors are cleaned, ECT`s value is agree with coolant temperature (I haven`t changed it), fuel and air filters are new.
Does anyone can help me?
thanks
.My VW have a problem
, it doesn`t have any power after the first start of the day (in the morning), or when it has been more than 5 hours turned off. The car had the DTC p1128, p0131 and misfire codes.I changed the lambda sensor and the p0131 disapeared, also I changed the AFM and the p1128 is out too, I erased the misfire codes and they never come back, but the problem is still present
. The problem is like lean mixture.After 2 or 3 minutes the car improves a little and I can drive it normally.
thanks
The only things I can think of are checking your oil pressure to see if you have a bad oil pump or a clogged pick up tube where the oil has to get thinner for them to work properly or, maybe a vacuum leak. Though it would be strange for a vacuum leak to stop after it warms up.
thanks for your advice!!!
I`ll check that, ... mmmm... or better, I`ll change the oil (and check pressure) tomorrow or next Saturday.
I checked vacuum leaks and there aren`t any.
I`ll let you know the results
bye
bye
admiralbrown
Jan 16, 2010 02:11 AM
phil346533
Apr 17, 2005 05:24 PM
