Jetta Throttle Body
Old Sep 22, 2020 | 06:02 PM
DrStupid's Avatar
Default Jetta Throttle Body
Hello all. First timer. I have a 2010 Jetta With the 2.5 Five cylinder engine. We bought her brand new for my wife. Our youngest is driving it now. He says it is loosing power and wants to stall and the EPC and ENGINE Lights are on. I drove it and couldn’t duplicate the issue. (He has zero car knowledge. I know, I’ve failed him) I bought a scanner tool and it indicates a 25% chance it’s the throttle body. I changed the air filter because that was the second possibility. The Throttle body doesn’t look difficult for me to do at all.
I have 4 questions.
1. Why are the prices from $60.00 to $650.00?
2. Is this a remove and install or is there any programming?
3. Does anyone think it’s something else or have any opinions?
4. Is OEM very important here?
I appreciate any advice from the crowd.
Thank You
Jay C
Old Sep 24, 2020 | 07:52 AM
Old Sep 25, 2020 | 01:57 PM
DrStupid's Avatar
Thank you for the reply Keithuk. OK, the error codes are p0300, p0302, p0303 & p0304. The scanner I have indicates random misfires & misfires in cylinder 2, 3 & 4. I think I’m going to change all 5 coils and the spark plugs. Anyone have similar issues with these codes and found out it was a different fix or does it sound like the right track?
And sorry for the delay responding.
Jay C
Old Sep 26, 2020 | 09:08 AM
Were those error codes taken of VAG-COM\VCDS or a generic scanner?
VAG Error Code: 16684/15137/10203/4051/000768
EOBD II Error Code: P0300
Fault Location:
Random/Multiple Cylinder(s) - Misfire Detected/Upper Limit Exceeded/Implausible Signal
Possible Cause:
Wiring/Connector(s).
Air Intake System leaking.
Fuel Supply faulty.
Injector(s) faulty.
Ignition coil(s) faulty.
Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open.
Camshaft Position (Hall) Sensor (G40) faulty.
Low compression.
Possible Solutions:
Check Misfire Recognition.
Check Air Intake System.
Check Fuel Supply.
Check Ignition Coil(s).
Check Camshaft Position (Hall) Sensor (G40).
Check cylinder compressions.
Special Notes:
This Diagnostic Trouble Code (DTC) indicates that one or multiple cylinders are misfiring, but the Electronic Control Unit (ECU) fails to identify the cylinder.
Tech Notes:
The P0300 code means that a cylinder(s) is misfiring or is randomly misfiring. Start by checking for intake leaks, intake gaskets are common caused of multi-cylinder misfiring. If no leak are found the next step is to replace the spark plugs. If the problem persist more tests needs to be done to diagnose problem.
When is the code detected?:
The control module monitors the crankshaft speed and has detected a misfire condition.
Description:
When a misfire occurs, engine speed will fluctuate. If the engine speed fluctuates enough to cause the Engine Speed (RPM) Sensor (G28)/Crankshaft Position Sensor (G28) signal to vary, the Engine Control Module (ECM) can determine that a misfire is occurring.
VAG Error Code: 16686/15128/10592/7115/8736/4057/000770
EOBD II Error Code: P0302
Fault Location:
Cylinder 2 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Running out of fuel.
EVAP canister purge valve.
Evaporative emission system.
Low compression.
Base engine problems.
Engine Control Module (ECM) damaged.
Possible Solutions:
Do a compression test.
Read Measuring Value Blocks (MVB) 15 if misfire changes location.
Special Notes:
Tech Notes:
The P0302 code means that the cylinder 2 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 2. If the problem persist more tests needs to be done to diagnose problem.
Description:
VAG Error Code: 16687/10593/6352/4060/000771
EOBD II Error Code: P0303
Fault Location:
Cylinder 3 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Possible Solutions:
Special Notes:
Tech Notes:
The P0303 code means that the cylinder 3 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 3. If the problem persist more tests needs to be done to diagnose problem.
Description:
VAG Error Code: 16688/10594/4063/000772
EOBD II Error Code: P0304
Fault Location:
Cylinder 4 - Misfire Detected
Possible Cause:
Lack/loss of power.
Hard start.
Engine hesitation.
Ignition system.
Fuel injectors.
Fuel pressure.
Low compression.
Possible Solutions:
Special Notes:
Tech Notes:
The P0304 code means that the cylinder 4 is misfiring or is randomly misfiring. Start by checking for intake leaks an if no leaks are found the next step is to replace the spark plugs on cylinder 4. If the problem persist more tests needs to be done to diagnose problem.
Description:
Old Oct 5, 2020 | 07:40 AM
DrStupid's Avatar
Default Done
I have no idea why but I couldn’t send a reply due to some token thing timing out or whatever. I don’t know. Technology and me don’t jive very well. I’m always the one with some BS issue.
Long story short.
To answer your question. It’s a INNOVA Fix Assist + Repair Solutions 2.
Cylabder 3 had a broken and disintegrated rubber boot inside causing a spark and burning the spark plug. Probably the original parts. I changed all 5 plugs and coils. Runs well now.
Thank You for your help and advice.
Jay C
CharlieB
Dec 24, 2013 12:25 AM
mcr122
Jan 6, 2011 02:45 PM
Nov 19, 2010 12:02 AM
polebridge
Feb 11, 2009 01:28 PM
d_moser
Feb 22, 2006 04:20 PM
