Help cant figure out my Jetta car problems
Old Feb 27, 2018 | 01:28 PM
JETTAJR619's Avatar
Unhappy Help cant figure out my Jetta car problems
I have a 2001 jetta 1.8t wolfsberg ed. A couple weeks ago the thing just died while driving. I changed the computer,fuel pump relay, ecm relay and it still wont start. I checked for spark and all cylinders r sparking. I checked for fuel at injectors, they have it. Now wen i turn ignition motor turns but does not sound normal, it sounds like an electric motor. Can anybody help?
Old Feb 28, 2018 | 07:07 AM
That's isn't easy to diagnose on the web going by the text posted.
You need to get your motor scanned (preferably with VAG-COM\VCDS) for any error codes logged in the ecu and post them, that will save a lot of guessing, and check systems out.
Post moved to correct section as OP can't read sub forum titles.
Old Mar 8, 2018 | 07:29 PM
diesel bloke's Avatar
sounds like no compression.has your timing belt jumped or come loose.it would be unusual for lifters to collapse,especially all off them.do a quick compression test thru spark plug holes,check timing.
mikey7533
Nov 10, 2007 09:44 AM
bradleygt2
Nov 9, 2007 03:39 PM
DIY_Heather
Sep 29, 2007 02:42 AM
skfootballer23
Aug 1, 2006 11:55 AM
