Help with 2000 Jetta GLX VR6 Auto-Dimming Rear View Mirror Replacement
Old Jan 26, 2025 | 10:30 PM
ghelfrich's Avatar
Default Help with 2000 Jetta GLX VR6 Auto-Dimming Rear View Mirror Replacement
My 2000 Jetta GLX VR6 has the auto-dimming rear view mirror as well as the windshield rain sensor. The dark fluid in the mirror is leaking out and it's to the point of needing replaced.
This weekend I've been trying to track down a replacement rear view mirror. I have looked and looked and can't seem to find one online anywhere. I'm thinking I may just need to look at a junkyard.
I guess what I also don't understand is if the auto-dimming mirror is different for a car such as mine that does vs doesn't have the rain sensor? From what I see, the rain sensor is attached to the windshield, and the rear-view mirror attaches to it for those cars that have it.
I want to make sure I understand exactly what I need so I don't buy the wrong thing online if I find one and can tell the junkyard exactly what I need if that's the way I go.
Also, is my only option to replace it with a used mirror? Or are there any after-market mirrors that work in my car without modification(s)?
Does someone have a good write-up they could point me to so I can learn how to replace this mirror and understand what needs to be done?
Thanks in advance.
Gerry
Old May 31, 2026 | 10:08 AM
DylanSanders112's Avatar
Pokud máš dešťový senzor, je dobré hledat zrcátko ze stejné výbavy nebo alespoň z vozu, který měl stejný držák a senzorový modul. Samotný senzor je sice připevněný k čelnímu sklu, ale zrcátko a jeho uchycení se mohou mezi verzemi lišit. Vrakoviště bývá často nejjednodušší a nejlevnější řešení, protože nové originální díly už se shánějí obtížně. Existují i některé aftermarket varianty, ale většinou vyžadují úpravy zapojení nebo uchycení. Výměna samotného zrcátka obvykle není složitá, jen je potřeba opatrně odpojit konektor a uvolnit zrcátko z držáku bez poškození senzoru. Mostbet přináší výhodné bonusy a cashback mostbet bonus https://mostbet-casinoonline.cz/bonusy/ programy.
lightning84
Feb 4, 2012 08:41 AM
Nairoc
Oct 3, 2011 07:22 PM
Dixiecharm
Jul 2, 2011 11:05 PM
infinitron
Apr 22, 2009 07:01 PM
bob99pass
Aug 12, 2007 08:33 PM
