Electrical Problems w/2006 Jetta
Old Oct 24, 2008 | 07:24 PM
jrscpu's Avatar
Default Electrical Problems w/2006 Jetta
Just got this 2006 Jetta Value Edition used. Tonight I parked the car, turned-off the ignition and pulled out the key. When I opened the door, I was greeted with a alarm that tells you your headlight were left on. I got out and noticed the front driver's side headlight, side marker and tailight was on. Just the driver's side! Tried restarting and turning off again with no effect. I pulled out the manual and found out there were 2 fuse boxes. The one in the engine compartment had two 40 amp fuses. One turned off the front and then the other took care of the back. Unfortunately, I couldn't start the car with them out. I put them both back and those lights kept coming on. I figured, lets get it started, put it in garage and then I would have to pull those fuses out again. When I got into the garage the problem went away! I'll visit the dealer tomorrow but wanted to know your thoughts. Thanks.
Old Oct 24, 2008 | 07:49 PM
Jrailer's Avatar
Default RE: Electrical Problems w/2006 Jetta
did you turn thehead ltswitch to far to the left ?
i think they have a park lt circut that will only light up half the car
some kind of european thing
Old Oct 25, 2008 | 08:08 PM
jrscpu's Avatar
You are right. When I got to the dealer he also said
that it's a European Light Standard.( If you ask me,
the Battery Manufacturer's had a hand in it too!)
Pulling the fuses, though, he said would have created
Error Codes on the OBDII so he had them cleared.
It shows you how out of date I am since my last
car is a 1996 Jetta Trek! That was an amazing
car that I'm selling and it has 218,500 miles and
still doesn't burn a drop of Castrol Syntex yet!
Thanks for replying.
Old Oct 25, 2008 | 08:44 PM
Jrailer's Avatar
no problem glad to help
ATaylor
Apr 13, 2012 12:01 PM
frustrated_jetta_owner
Nov 11, 2009 05:43 AM
CJBEAR007
Jun 8, 2009 09:39 PM
missaba
Apr 7, 2008 12:02 PM
jetta16x
Mar 21, 2008 09:35 AM
