DTC Help - 3 Codes that won't reset
Here's my issue - I have a 2013 Jetta Sportwagon TDI - WITH a salvage title so my car has NO warranty.
I have 3 trouble codes that VAG-COM can not clear. I'm not sure what to do here. Any help or suggestions would be much appreciated!
Here they are:
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C49230001880E06ED921F0042B70000
Shop #: WSC 00066 000 00000
VCID: 7DF1E4F5E40372F6F01-8028
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Time Indication: 0
Date: 2022.14.01
Time: 19:13:54
Freeze Frame:
Count: 0
Count: 14
Count: 20480
Count: 16401
Count: 45568
Count: 10752
Count: 1281
Count: 0
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 J HW: 5K0 937 084 J
Component: BCM PQ35 B 021 1068
Revision: BG021001
Coding: 6F380E1F802F3EC4008800C17000004449000086575D05F064 802020A040
VCID: 397930E5B0AB8ED69C9-806C
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 11081 26 0512
Coding: 009795
1 Fault Found:
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 4
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Time Indication: 0
Date: 2022.14.01
Time: 19:13:55
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 D HW: 1K0 035 274 D
Component: RNS315-NAR H53 0319
Serial number: VWZAZ2M4265464
Coding: 04000401040007000000100A
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS 001705
ROD: EV_RNS315NARV2UDS.rod
VCID: 2541EC9524131A36C81-8070
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V3_(0037) 0037
1 Fault Found:
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Date: 2022.14.01
Time: 19:13:53
Here they are:
Revision: 00H31001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Time Indication: 0
Date: 2022.14.01
Time: 19:13:54
Freeze Frame:
Count: 0
Count: 14
Count: 20480
Count: 16401
Count: 45568
Count: 10752
Count: 1281
Count: 0
Revision: BG021001
Coding: 009795
1 Fault Found:
00955 - Key 1
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Time Indication: 0
Date: 2022.14.01
Time: 19:13:55
Freeze Frame:
Term 15 On
Voltage: 12.65 V
ON
ON
OFF
OFF
OFF
Data medium:
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 73
Mileage: 46044 km
Date: 2022.14.01
Time: 19:13:53
VAG Error Code: 02214
Fault Location:
Tyre Pressure Warning - Lower Limit Exceeded - Intermittent
Possible Cause:
Tyre Pressure Monitoring found a low pressure.
Even though the tyre pressures where checked and topped up and the SET button pressed this error code still logs in the ecu.
Possible Solutions:
Just clear the DTC and everything should be ok.
It will be logged again in the ecu if the Tyre Pressure Warning Light comes back on.
Reset Tyre Pressure Monitoring.
Fault Location:
Possible Cause:
Possible Solutions:
VAG Error Code: 00955
Fault Location:
Key 1 - Adaptation Limit Surpassed - Intermittent
Possible Cause:
Key/Remote Control not operational.
Key/Remote Control not matched.
Key operated more than 200 times while out of range.
Possible Solutions:
See vehicle specific page for synchronisation/adaptation procedures.
Fault Location:
Possible Cause:
Possible Solutions:
Fault Location:
Key 1 - Adaptation Limit Exceeded - Intermittent
Possible Cause:
Key/Remote Control Battery low/faulty.
Fault Location:
Possible Cause:
VAG Error Code: 1048669
EOBD II Error Code: B11CF
Fault Location:
Tuner for Satellite Radio - Deactivated
Possible Cause:
Digital Satellite Tuner in Demo Mode.
Digital Satellite Tuner not enabled.
XM/Sirius not activated.
Special Notes:
This fault code is only a note, it will disappear once the XM/Sirius Subscription is renewed.
Fault Location:
Possible Cause:
Special Notes:
Thank you for the detailed info.
1) TPMS - It won't reset period. I sit in the car try to reset fault codes and says "OK" and rescan and it's still there. No starting the car or anything.
2) Key - I'll give this a try - Good idea
3) Nav/Sat radio - I was thinking this might be the case but wasn't sure.
Thank you for your thoughts on this and pointing me in a direction to try a few things!
Nov 24, 2010 04:15 AM
