Cleaning valves
Old May 2, 2008 | 05:39 PM
racerx002's Avatar
Default Cleaning valves
I was wondering if there was any way to clean the carbon build-up on valves without having to remove the head.
Thanks
Old May 2, 2008 | 11:00 PM
Jrailer's Avatar
Default RE: Cleaning valves
allot of your fuelinjector cleaners clame to do the trick
Old Apr 15, 2009 | 08:03 PM
jtd_1's Avatar
Does any one use seafoam treatments on VW's? I use it on my Z28 Camaro, and it works beautifully. I know this is an old thread, but i am new (again) to the vw world. It is amazing how much crap comes out the exhaust (smoke) from seafoaming.
Old Apr 16, 2009 | 11:07 AM
racerx002's Avatar
Seafoam away!
Old Apr 16, 2009 | 12:30 PM
jtd_1's Avatar
racer, have you done it to your car?
Also did you do it using the brake booster? Use about half a bottle and make it die on the last bit of seafoam, soak (engine off) for 15, than run and drive it hard to get rid of everything?
Old Apr 17, 2009 | 07:26 AM
racerx002's Avatar
I just do it through the throttle body but, that puts up an engine code that you can just clear off if you have a scanner. The brake booster should work fine. I think you just let it soak for 5 min. I do it every 5,000 miles.
haybayian2011
Oct 29, 2010 04:13 PM
JL
Mar 27, 2008 09:57 AM
Hoppah
Jul 25, 2007 08:42 PM
e10sp
Mar 9, 2007 05:50 AM
cody
Jan 1, 2007 09:08 PM
