Brake noise for the first few minutes
Old Jan 10, 2009 | 04:57 PM
BriGreentea's Avatar
Default Brake noise for the first few minutes
Ever since I bought my 07 Jetta the dealer told me they replaced the brakes and may hear some squeaking because water got in there. Well, it still happens. When I turn on my car after it's been sitting for awhile I can hear some high pitch break squeaking in the rear. After the car is driving around for a minute or so it will go away completely.
Anyone have an idea what is causing this? Brake fluid not pumping at the start quickly?
Old Jan 10, 2009 | 04:59 PM
racerx002's Avatar
Default RE: Brake noise for the first few minutes
Do you park outside? Could just be the rust that forms when your outside.
Old Jan 12, 2009 | 01:57 PM
dbaseballs's Avatar
brakes squeak no matter what, there are certain things that make it so you can hear it like if you get a lot of dirt on your rotors it will most likely squeak for you it sounds like once the car warms up it goes away so i dont think its anything to worry about
kenzq
Jan 6, 2011 09:31 PM
Tbraase
Oct 5, 2009 10:06 PM
bamaresearch
May 10, 2007 04:00 AM
jlb532
May 7, 2007 10:43 PM
corvette6698512
Apr 10, 2006 02:10 AM
