Brake failures
Old Mar 9, 2019 | 09:43 PM
Pedro Panades's Avatar
Default Brake failures
Hey guys I’m having problems with my mk6 Jetta , after the car warms up the brakes starts to fade . When I press the brake the car does not stop right away it stills go on for some more than it stops , and even when I slam in game brakes it does not stop, any ideia what it might be going on
Old Mar 10, 2019 | 10:56 AM
When was the brake fluid last flushed and replaced, every 3 years? You need to check the brake servo is working. A quick check is stop the engine pump the brake pedal a few times to exhaust any vacuum in the system. Hold your foot on the brake pedal and start the engine, the brake pedal should move down slightly.
Old Mar 10, 2019 | 06:17 PM
So if the brakes go down after I start the engine is that bad or good ?
Old Mar 11, 2019 | 08:48 AM
As I've said the brake pedal should move down slightly when you start the engine, that means the brake servo is working. There could be restricted vacuum check all pipes and connections.
You don't say which engine is fitted to this Jetta. Petrol engines have vacuum in the inlet manifold all the time. Diesel engines don't have vacuum they use an exhauster (vacuum pump) to make the vacuum for the brake servo.
Old Mar 11, 2019 | 09:04 AM
I have a 2.5 2011 Jetta gasoline engine , and from what I saw it’s the brake fluid that is bad ... thank you
EmLane
Nov 24, 2019 10:10 AM
DonM77
Apr 27, 2008 01:09 PM
jettagirl
Feb 10, 2008 09:54 PM
Jetta 2.0
Oct 31, 2007 12:40 AM
fdunne
Jan 13, 2006 12:35 AM
