98 jetta ignition problems?
Old Jan 13, 2008 | 11:23 PM
ihrigch's Avatar
Default 98 jetta ignition problems?
The other day I went to drive my girlfriends 98 Jetta and it wouldn’t start. After looking under the hood I noticed that there was a small spark coming from the ignition coil. I tested to see if that was the problem by wrapping electrical tape around the spot and the car started right up. So I decided to replace the ignition coil along with the cap rotor wires and plugs. Now the car idles very low and when I try to accelerate the engine cuts out around 200 RPM’s. Any Idea’s
Old Feb 11, 2008 | 05:36 AM
moore994's Avatar
Default RE: 98 jetta ignition problems?
dumb question. Are you sure you hooked all your plugs back up in the right order?
Old Feb 11, 2008 | 10:46 AM
ihrigch's Avatar
who the **** are you to be calling people dumb. of course I checked all the plugs. actually It was the throttle body that was going bad. her is an idea, if you don't know what you are talking about then save yourself some energy.
check the plugs, your a ****'n retard. my 10 year old could have told me that.
Old Feb 20, 2008 | 05:49 PM
bagel's Avatar
If you plan on staying a member of these forums, this behavior WILL NOT be tolerated!! Maybe he was trying to help, simply stating that maybe you connected 1 or 2 wires in the wrong spots. Either way, no one is the best or worst mechanic but everyone is entitled to their own opinions....if you can't handle that than I suggest you find another forum.
finkdog2004
Feb 22, 2009 09:32 PM
DW
Mar 11, 2008 06:02 PM
Jenuwine
Jul 16, 2007 09:12 PM
nikki
Apr 27, 2007 08:19 PM
gsxr1100
Jan 31, 2007 08:52 AM
