2008 jetta hid ballast big problem
Old Jan 12, 2008 | 12:17 AM
intel_908's Avatar
Default 2008 jetta hid ballast big problem
Ok.. I have a big problem.. i have oem hids on my 2008 jetta, and I bought 10 000k hid, bulb only. I remove the cover, remove the oem ballast, put the new bulb, spent 1 hour trying to put the whole thing together... and finally succeed on the passenger side. Now for the driver side, it becomes tricky. On the oem ballast, when you turn it, a white clip inside the small connetor pops( the one that connects the ballast to the car) that make fall the wire and dissamble the ballast, the plastic ring and the bulb. The problem iswe played a little bit onthat connector to see how it was made and when we put back the wire, the plastic clip wentvery far in the ballast. Wecan actually see itwith aflashlight. Now the original bulb and the oem ballast are totally stuck together.. We tried to pull the white clip out without success So know I have to find a way to separate the oem bulb from the ballast..
Any suggestion will be greatly appreciated!!
Thank you very much
comeinchina
Oct 16, 2009 03:02 AM
sir_honeytoast@yahoo
Aug 19, 2008 06:18 PM
bradh
Mar 23, 2008 12:57 PM
63 MPG
Oct 20, 2007 03:09 AM
John
Oct 9, 2007 05:38 PM
