2003 Jetta Overheating
Old Sep 21, 2017 | 08:36 AM
Jodey Peters's Avatar
Default 2003 Jetta Overheating
Bought my kid a 2003 Jetta from a friend about 6 months ago.
It started leaking coolant and overheating a few months ago and I haven't had time to really look into it so it's been sitting.
What's happening is the temp light comes on due to low water. Then the temp will start to rise. It rises when idling. When I drive or simply rev engine the temp comes back to normal. At least for a few minutes until it leaks enough water out that it can't recover.
I've been busy and haven't even looked under vehicle to see where leak is coming from but my initial thought is this is the water pump. Am I on the right track?
Old Sep 22, 2017 | 05:52 AM
Is that a 2003 Jetta petrol or diesel?
You need to get it pressure tested.
Post moved to correct section as user can't read sub forum titles.
dsparks
Jul 25, 2012 08:34 AM
cliiff
Jun 6, 2012 09:42 PM
khakiVeeDUB
Sep 11, 2007 12:37 AM
NAFAN21
Jul 31, 2006 10:51 PM
