2002 Jetta GLS problem Code P0411, Solenoid Question
Old Jan 26, 2009 | 04:37 PM
whitewolf8's Avatar
Default 2002 Jetta GLS problem Code P0411, Solenoid Question
Hi guys I own a 2002 Jetta GlS, 1.8T. Recently I pulled codes on the vehicle and I have a p0411 code after extensive research as far as I understand the possible problems are a bad air pump, combi valve, or Solenoid
The issue is A. Im having trouble finding the secondary injection solenoid, I thought this was it but Im not sure
http://www.mjmautohaus.com/catalog/product_info.php?info=OEM_VAG_058906283F_Boost_Pre ssure_Valve_N75_%22F%22_Valve_OEM&products_id= 1721
I think that it may be the solenoid I hooked a voltmeter to it and I got 12 volts of power to the solenoid but upon turning the car on or putting the ignition on I couldnt hear the solenoid switch on. I assume its the solenoid the car's still running great the only evidence of this is the check engine light but I feel I may be wrong about that solenoid as it costs 108 dollars and other forums said it only costs like 8 to 11 and I feel maybe Im going after the wrong thing here. If any of you can help me out could you tell me where the solenoid is?
Mon Jan 26, 2009 10:21 pm
Old Jan 26, 2009 | 04:51 PM
bagel's Avatar
Default RE: 2002 Jetta GLS problem Code P0411, Solenoid Question
From what I gather, the problems would be Secondary air injection system, incorrect flow. Is that what you downloaded??
Old Feb 8, 2009 | 06:36 PM
whitewolf8's Avatar
Yes that is correct, It turned out not to be the solenoid, I went ahead and replaced it and check engine light came back on so Im guessing its a bad combi valve the air pump is working I can feel a vaccueem when I place my hand on the solenoid valve.
Thats correct the problem is with the secondary air injection system incorrect flow
Old Feb 11, 2009 | 02:55 PM
whitewolf8's Avatar
I need advice, I dont know what to do at this point to fix this problem I ran a smoke test through the air system and I had no leaks so I ruled that out but thats all Ive got atm
JazzJam
Nov 22, 2023 04:28 AM
grocerman2007
Apr 6, 2023 08:47 PM
dcom5
Apr 18, 2012 05:17 AM
PowerAddict
Apr 6, 2011 09:08 PM
elrocco88
Jul 5, 2010 03:12 AM
