1999.5 Vw jetta mk4 2.0 engine code P0302
Old May 17, 2011 | 10:46 AM
Johnny29's Avatar
Default 1999.5 Vw jetta mk4 2.0 engine code P0302
I have a 1999.5 mk4 Vw Jetta 2.0 89k. When I just start the car, the engine shakes and a code P0302 showed up. When the engine is warm ( 2-3 min later) the engine dosen't shake as much but still dosen't work propertly,on 1500-2000rpm's its not shaking,runs ok but same code comes back.I replaced Wires, ignition coil,injector,checked eveything and came to dead end. What can be the problem?
Old May 17, 2011 | 03:39 PM
elrocco88's Avatar
The code means: Cylinder number two misfire dectected. Did you replaced the injector??
Old May 17, 2011 | 03:52 PM
Johnny29's Avatar
Yes i did.. i mentioned in post.
jestepp
Apr 21, 2022 02:59 PM
MK4 Jetta
Aug 29, 2010 04:34 PM
vgolfdict
Mar 20, 2010 08:17 AM
KenAEM
Sep 22, 2006 06:56 PM
KenAEM
Sep 19, 2006 04:17 PM
