1999.5 Vw jetta mk4 2.0 engine code P0302
I have a 1999.5 mk4 Vw Jetta 2.0 89k. When I just start the car, the engine shakes and a code P0302 showed up. When the engine is warm ( 2-3 min later) the engine dosen't shake as much but still dosen't work propertly,on 1500-2000rpm's its not shaking,runs ok but same code comes back.I replaced Wires, ignition coil,injector,checked eveything and came to dead end. What can be the problem?
The code means: Cylinder number two misfire dectected. Did you replaced the injector??
Originally Posted by elrocco88
(Post 53809)
Yes i did.. i mentioned in post. |
