1.9 tdi 100pd issue
Old Apr 10, 2020 | 03:29 PM
Hughes2020's Avatar
Default 1.9 tdi 100pd issue
Hi guys, a friend and I are having an issue with a 100pd vw engine. We are looking to run the engine without any electrical wiring. Is this at all possible or is there anyway to reduce the amount of parts that would require electrical components. Thanks in advance.
Old Apr 11, 2020 | 07:25 AM
Which VW 100PD engine and year?
Old Apr 11, 2020 | 11:19 AM
Hughes2020's Avatar
Sorry for the mistake kieth I intend to stick around!
the engine code for the car is ATD is came out of a 2004 Bora
Old Apr 12, 2020 | 10:06 AM
Engine swapping isn't an easy job, the engine may physically fit but the other components need to be coded with VAG-COM/VCDS as they aren't plug and play.
Manufacturer: VW, Date(s) Used: 08/2003-05/2006, Model: Bora, Engine Code: ATD, 74Kw, 100PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt
Manufacturer: VW, Date(s) Used: 01/2000-09/2000, Model: Bora/Variant/4Motion, Engine Code: ATD, 74Kw, 100PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt
Feb 13, 2011 02:26 AM
miller
Aug 23, 2010 03:16 PM
lewyt666
Mar 21, 2009 11:56 AM
donkey
Jun 17, 2008 08:39 AM
7Star
Dec 21, 2007 09:36 AM
