1.9 tdi 100pd issue
Hi guys, a friend and I are having an issue with a 100pd vw engine. We are looking to run the engine without any electrical wiring. Is this at all possible or is there anyway to reduce the amount of parts that would require electrical components. Thanks in advance.
Default Welcome to Volkswagen Forum - Rules & Recommendations Which VW 100PD engine and year? |
Sorry for the mistake kieth I intend to stick around!
the engine code for the car is ATD is came out of a 2004 Bora |
Engine swapping isn't an easy job, the engine may physically fit but the other components need to be coded with VAG-COM/VCDS as they aren't plug and play.
Manufacturer: VW, Date(s) Used: 08/2003-05/2006, Model: Bora, Engine Code: ATD, 74Kw, 100PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt Manufacturer: VW, Date(s) Used: 01/2000-09/2000, Model: Bora/Variant/4Motion, Engine Code: ATD, 74Kw, 100PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) Timing belt |
