04 Jetta, coolant in oil. head pressure test ok
Old Dec 29, 2010 | 12:13 PM
piyush123's Avatar
Default 04 Jetta, coolant in oil. head pressure test ok
th ought possible head gasket removed head and sent to be pressure tested. test ok. excessive carbon and oil throughout intake. headgasket appeared to be ok. at time of repairs car smoked and sputtered, no power and couldnt advance rpms. pistons and sleeves looked fine. any help is greatly appreciated.
Old Jan 2, 2011 | 10:53 AM
smar969905's Avatar
Member
did you look at the head gasket itself? sounds like this motor was not taken care of much. while the head is in, you should have a shop clean it out chemically for you. as long as you have the motor torn apart, might as well give it a little love and replace o-rings on pistons and a few other gaskets. i'm going to guess that the oil is probably thick and black as well in there. make sure to change the oil and engine coolant. with coolant in the oil, there will also be oil in the coolant.
Alex5357aa
Nov 1, 2012 12:38 PM
elferi
Jan 25, 2011 11:34 AM
JL
Mar 27, 2008 09:57 AM
Boy_Narf
Mar 23, 2008 02:48 PM
sirhcsenrab
Apr 3, 2006 02:10 PM
