Oil Filter
Old May 3, 2005 | 11:00 AM
Gopher2005's Avatar
Default Oil Filter
Have A 2005 2.0 Liter Tdi.I attempted To Change The Oil But Cant Seem To Find The Oil Filter Or Drain Plug.Need Help
Thanks
Gopher
Old May 5, 2005 | 10:21 PM
patrick's Avatar
Administrator
Default RE: Oil Filter
if you have the owners manual, it should surely outline this for you! i havent worked on one for a while so i dont remember.
Old Oct 13, 2005 | 08:17 PM
toledotom's Avatar
I own a 2004 TDI Jetta Wagon with the same 2.0 diesel engine. The oil drain plug is on the oil pan beneath the engine as always! You have to remove the skid plate (plastic guard) to get under the engine. BE CAREFUL when u raise the car, make sure you are using the proper lifting areas. LOOK at your owner's manual. The oil filter is right in front of you when you open the engine. look for a round cylinder about 8 " long maybe 3" wide sits right in front when you open hood next to engine. Originally you might need a strap wrench to loosen top - but normally a strong hand will turn it counter clowise to expose dirty filter. It is a drop in paper type filter (no Metal like others). Remember to change O rings which come with filter. IF you are NOT EXPERIENCED mechanic or have not changed oil very often DO NOT ATTEMPT THIS! DO NOT take it to 15 minute oil change place, this car is a differant animal. Your dealer normally will change oil for a cheaper fee the first time or send coupons out in the mail. Ask them for a deal on oil changes........pays to have someone due it right, then have it done wrong and PAY BIG $$$ later. OH YES - USE synthetic OIL ONLY. The car come swith synthetic oil when new..DO NOT switch or it will not be under warranty! I use 10w - 30w Mobil 1 best place to buy is Sam's club unless Murray's has a rebate or it is on sale! [:@]
Old Oct 17, 2005 | 02:16 PM
patrick's Avatar
Administrator
hmm..i forgot all about those plastic cooling shields...they were a terrible hassle with which to deal.
go2bobp
Mar 4, 2007 12:52 AM
pillihp
Jan 3, 2007 05:56 PM
robsob
Jan 1, 2007 09:04 PM
bob174
Dec 9, 2006 10:23 PM
lw.johnston
Aug 14, 2005 10:28 PM
