WV golf check engine light
Old Dec 8, 2011 | 11:36 AM
vampzena's Avatar
Default WV golf check engine light
WV golf check engine light just came in i checked the codes i got after computer scanning , i got 7 codes all of them related to the gear (Wiring/Connectors from/to Solenoid Valve 2 (N89) Open or Short to Ground)....
Well i was shocked and surprised since the car is working well and i cant feel anything wrong with my gear transmission.
So i told the guy who did the scanning that i changed the gear before 4 months and i just have changed the battery today.
he said so it is normal since they are a new ratios to the computer not the original and the car is safe.
shall i blv him and forget this stupid light ? and is there any way to turn it off ?? my car is golf 2003
Old Dec 8, 2011 | 11:45 AM
Ok your new problem.
Can you please post the 7 errors displayed when you had the computer scan?
Old Dec 8, 2011 | 11:51 AM
vampzena's Avatar
00258 solenoid 1-n88 , open circuit
00260 solenoid 2-n89 , open circuit
00262 solenoid 3-n90 , open circuit
00264 solenoid 4-n91 , open circuit
00266 solenoid 5-n92 , open circuit
00268 solenoid 6-n93 , open circuit
00270 solenoid 7-n94 , open circuit
Old Dec 8, 2011 | 01:14 PM
EOBD II Error Code: 00258
Fault Location:
Solenoid Valve 1 (N88): Open or Short to Ground
Possible Cause:
Wiring/Connectors from/to Solenoid Valve 1 (N88) Open or Short to Ground.
Solenoid Valve 1 (N88) faulty.
Possible Solutions:
Check/Repair Wiring/Connectors from/to Solenoid Valve 1 (N88).
Check/Replace Solenoid Valve 1 (N88).
See Measuring Value Blocks (MVB).
Perform Output Test.
Well all those are virtually the same type of error but with different solenoid valves with the same cause and solution.
You would need someone with VAG-COM\VCDS to check the Measuring Value Blocks values.
As taken from my Free EOBD II Error Codes software
Old Dec 10, 2011 | 09:53 AM
vampzena's Avatar
thank you man i went to the mechanic today two instead of one of them said it os the solenoid valve problem and the other said it is the control unit and the speed sensor which one is right ????
Old Dec 10, 2011 | 01:45 PM
I couldn't really say which one but as I've said
"You would need someone with VAG-COM\VCDS to check the Measuring Value Blocks values".
Twoods12
Nov 19, 2010 07:55 AM
lilngineer
May 2, 2008 09:42 AM
drioux
Apr 1, 2008 12:47 PM
magea
Oct 18, 2007 08:12 PM
magea
Oct 8, 2007 10:55 PM
