WV golf check engine light
WV golf check engine light just came in i checked the codes i got after computer scanning , i got 7 codes all of them related to the gear (Wiring/Connectors from/to Solenoid Valve 2 (N89) Open or Short to Ground)....
Well i was shocked and surprised since the car is working well and i cant feel anything wrong with my gear transmission. So i told the guy who did the scanning that i changed the gear before 4 months and i just have changed the battery today. he said so it is normal since they are a new ratios to the computer not the original and the car is safe. shall i blv him and forget this stupid light ? and is there any way to turn it off ?? my car is golf 2003 |
Ok your new problem.
Can you please post the 7 errors displayed when you had the computer scan? |
00258 solenoid 1-n88 , open circuit
00260 solenoid 2-n89 , open circuit 00262 solenoid 3-n90 , open circuit 00264 solenoid 4-n91 , open circuit 00266 solenoid 5-n92 , open circuit 00268 solenoid 6-n93 , open circuit 00270 solenoid 7-n94 , open circuit |
EOBD II Error Code: 00258
Fault Location: Solenoid Valve 1 (N88): Open or Short to Ground Possible Cause: Wiring/Connectors from/to Solenoid Valve 1 (N88) Open or Short to Ground. Solenoid Valve 1 (N88) faulty. Possible Solutions: Check/Repair Wiring/Connectors from/to Solenoid Valve 1 (N88). Check/Replace Solenoid Valve 1 (N88). See Measuring Value Blocks (MVB). Perform Output Test. Well all those are virtually the same type of error but with different solenoid valves with the same cause and solution. You would need someone with VAG-COM\VCDS to check the Measuring Value Blocks values. As taken from my Free EOBD II Error Codes software |
thank you man i went to the mechanic today two instead of one of them said it os the solenoid valve problem and the other said it is the control unit and the speed sensor which one is right ????
I couldn't really say which one but as I've said
"You would need someone with VAG-COM\VCDS to check the Measuring Value Blocks values". |
