Wrong battery Installation (Reversed)
Old Dec 7, 2011 | 12:12 PM
vampzena's Avatar
Default Wrong battery Installation (Reversed)
Hi , i have golf 2003 .Someone connected my car battery on the wrong way would this blow the computer? or it is just a burned fuse ???
Old Dec 7, 2011 | 05:06 PM
Yes it could do but it will damage the alternator first.
So who connected the battery up wrong an ex friend?
Doesn't the car start now?
Old Dec 8, 2011 | 01:03 AM
vampzena's Avatar
yes it doesnt start now i checked the fuse box one of them was not working and it is burned and i am wondering what would happen now !! ((
Old Dec 8, 2011 | 11:18 AM
So it doesn't start at all or it starts and runs for a second the stops that is the immobilizer working which can be another pain in the a**e to remove?
So you've checked all fuses and connections. The 109 relay in the fuse\relay box under the bonnet does go faulty so its worth carrying a spare in the car just in case when you do get it running.
Old Dec 8, 2011 | 11:35 AM
vampzena's Avatar
thank you man it is solved now and the car is working fine (it was wiring problem)... Now i have another problem ::
WV golf check engine light just came in i checked the codes i got after computer scanning , i got 7 codes all of them related to the gear (Wiring/Connectors from/to Solenoid Valve 2 (N89) Open or Short to Ground)....
Well i was shocked and surprised since the car is working well and i cant feel anything wrong with my gear transmission.
So i told the guy who did the scanning that i changed the gear before 4 months and i just have changed the battery today.
he said so it is normal since they are a new ratios to the computer not the original and the car is safe.
shall i blv him and forget this stupid light ? and is there any way to turn it off ?? my car is golf 2003
ocond97
Jul 24, 2008 11:43 PM
sknyppy
Feb 9, 2007 12:20 AM
bagel
Sep 1, 2006 09:36 PM
todd_jackson
Dec 29, 2005 12:44 AM
