Timing issue HELP!!
Old Sep 21, 2012 | 03:57 PM
atanasmk3's Avatar
Default Timing issue HELP!!
So I decided to mess with the timing on my golf. I removed the 13mm bolt and plate that holds the distributor, and I rotated the distributor clockwise.I test drove the car check engine light came on and lost power car was weak. I placed the dist. back in its original setting and my check engine light is still on.I tried to reset battery but its still on. what can I do??
thank you
cheers,
Old Sep 21, 2012 | 07:57 PM
Amateurs messing about with things they know nothing about.
You've made 3 others post that you haven't replied to.
Old Sep 21, 2012 | 11:57 PM
atanasmk3's Avatar
ya u could say I am amature ive working with hondas for over 10 years and been messing around with Vw for while, I owned a 87 scirocco 8v 4 years I did all work on it pulled motor out , new clutch etc. as far as my timing issue I just wanted to see if i can advance little. Now its back to factory setting but check engine is still on. as far other post sorry, i been busy with w golf and im painting my bike @same time. will get to em. any sugesttions how to clear Light. I hookedup OBDII scanner I reset but it came back on.
thank you
cheers
Old Sep 22, 2012 | 05:43 AM
Well if you've had a EOBD scanner plugged in did it show any error codes, if so please post them?
We need to know more details about your motor?
huyuhy
Nov 7, 2011 02:10 AM
pixie
May 12, 2011 11:50 PM
flex2slick
Oct 12, 2007 07:45 PM
jjjetta
Jan 2, 2007 02:41 AM
thedog
Jul 10, 2006 06:19 PM
