Throttle Body sensor fault code - Please help!!!
Hi Guys,
I have a golf mk3 auto 1.8. The car had difficulty starting when the engine was cold. After a diagnostic i was told that it was the throttle body sensor. This was changed. But after a couple of days the problem came back - cold start problems - but the car is fine when the engine warms up.
The error codes I get from a vagcom are;
Address 02: Auto Trans
1 Fault Found:
00518 - Throttle Position Sensor (G69)
16-10 - Signal Outside Specifications - Intermittent
Address 01: Engine
00515 - Camshaft Position (Hall) Sensor (G40)
03-00 - No Signal
Address 01: Engine
00516 - Closed Throttle (Idle) Position Switch (F60)
30-00 - Open or Short to Plus
I cannot do a throttle body alignment as I only have the shareware version of the vagcom software.
Some forums have indicated that is could be the main earth lead on gearbox, or a broken wire in the wiring loom that sits on top of starter motor??????????
any ideas!!!?????
1 Fault Found:
Address 01: Engine
03-00 - No Signal
Address 01: Engine
any ideas!!!?????
r.etheridge
Jan 3, 2011 05:08 PM
Nov 19, 2010 12:02 AM
