Throttle Body sensor fault code - Please help!!!
Hi Guys,
I have a golf mk3 auto 1.8. The car had difficulty starting when the engine was cold. After a diagnostic i was told that it was the throttle body sensor. This was changed. But after a couple of days the problem came back - cold start problems - but the car is fine when the engine warms up. The error codes I get from a vagcom are; Address 02: Auto Trans 1 Fault Found: 00518 - Throttle Position Sensor (G69) 16-10 - Signal Outside Specifications - Intermittent Address 01: Engine 00515 - Camshaft Position (Hall) Sensor (G40) 03-00 - No Signal Address 01: Engine 00516 - Closed Throttle (Idle) Position Switch (F60) 30-00 - Open or Short to Plus I cannot do a throttle body alignment as I only have the shareware version of the vagcom software. Some forums have indicated that is could be the main earth lead on gearbox, or a broken wire in the wiring loom that sits on top of starter motor?????????? any ideas!!!????? |
