some issues with my car, please help!
Old Sep 17, 2006 | 02:08 PM
WILL ARNOLD's Avatar
Default some issues with my car, please help!
i have a golf mk3 1992 -1993 model which has engine problems.
here are my problems:
it takes a fair few goes to start it up, sometimes have to rev it to get it going.
its uses loads of fuel.
it only starts idling correctly after a few minutes of tic-over. its runs at about 4-500 rpm if i dont press the gas pedal :S
here are the things that i have changed to try and rectify the problem:
spark plugs
distributor cap
coolant temp sensor
air intake sensor
also checked the wiring, and it seems ok, but i'm no electrician.
i did try for information from this forum before, but all that was suggested didn't help the matter too much
thanks
Will
Old Sep 18, 2006 | 01:14 PM
Joelzy's Avatar
Default RE: some issues with my car, please help!
could it be a fuel delivery problem? seems like a possbility, perhaps injectors or pump. I wish i could help but im not an expert.
Old Sep 19, 2006 | 03:12 PM
thanks for the advice, i think what happening is that the pumps is working normally, yet the injectors aren't limiting the amount of fuel that goes into the engine, merely letting it gush in!
Will
Old Sep 25, 2006 | 09:04 AM
hmm, on later inspection the injector is mint, aswell as the pressure regulator membrane..
anyone know how much it would cost to configure a new ecu to my car?
thanks
Will
Old Sep 25, 2006 | 02:05 PM
Joelzy's Avatar
swing and a miss... sorry i tried
danisang24
Nov 10, 2014 11:45 AM
chandlerking
Mar 25, 2010 11:02 AM
lucindatracey
Aug 9, 2009 05:22 PM
clash0901
Feb 23, 2009 10:26 PM
The VW Man
Jun 25, 2007 04:31 PM
