some issues with my car, please help!
i have a golf mk3 1992 -1993 model which has engine problems.
here are my problems: it takes a fair few goes to start it up, sometimes have to rev it to get it going. its uses loads of fuel. it only starts idling correctly after a few minutes of tic-over. its runs at about 4-500 rpm if i dont press the gas pedal :S here are the things that i have changed to try and rectify the problem: spark plugs distributor cap coolant temp sensor air intake sensor also checked the wiring, and it seems ok, but i'm no electrician. i did try for information from this forum before, but all that was suggested didn't help the matter too much thanks Will |
RE: some issues with my car, please help!
could it be a fuel delivery problem? seems like a possbility, perhaps injectors or pump. I wish i could help but im not an expert.
thanks for the advice, i think what happening is that the pumps is working normally, yet the injectors aren't limiting the amount of fuel that goes into the engine, merely letting it gush in!
Will |
hmm, on later inspection the injector is mint, aswell as the pressure regulator membrane..
anyone know how much it would cost to configure a new ecu to my car? thanks Will |
swing and a miss... sorry i tried
