PLEASE help ! wheres my fuel filter ? aahhh
Old Feb 26, 2007 | 09:37 PM
joemetro2000's Avatar
Default PLEASE help ! wheres my fuel filter ? aahhh
please, anyone know where my fuel filter in located? i looked all over can't find it. it not where my bmw one was. the car is not starting and my other cars heat is out.....i just bought a new filter but i can't find it on the car.
thanks for any info.
pjanebjane@aol.com
1996 vw golf gl 2.0L
Old Feb 27, 2007 | 02:26 PM
bagel's Avatar
Default RE: PLEASE help ! wheres my fuel filter ? aahhh
If it's not an in-line filter, than it's prolly in the gas tank.
Old Mar 2, 2007 | 10:37 PM
Nick's Avatar
If the filter is outside of the tank then it would be on the passenger side near the rear tire and if its in the tank your access hole is either under ur back see or under the lining in your trunk... If it is in the gas tank u need a speical tool to turn the seal off and be careful with the fuel pump and make sure you seal everything back correctly so u don't have n e leaks because that will throw the check engine light on...
Old Mar 9, 2007 | 10:27 PM
volksfanatic's Avatar
if you still can't find your VW fuel filter, maybe a repair manual would help..
surveyguyOR
Jan 18, 2009 09:12 PM
Meanie5470
Oct 14, 2007 08:04 PM
rookie mechanic
Mar 18, 2007 12:21 AM
gabenheimer
Aug 27, 2006 06:19 PM
wewantutopia
Aug 8, 2006 01:49 AM
