Heater coming out cold?
Old Dec 17, 2008 | 09:00 AM
onzlow's Avatar
Default Heater coming out cold?
Hi i have a mk3 golf 1800 se p reg,i have a problem with the heater?it blows out cold air,i have replaced the radiator,thermostat and thermostat housing but still no luck,i have now taken the thermostat out to see if it was faulty,all the pipes heat up even the ones that go into the heater matrix but still heaters come out cold,i took the water pump off and inspected it and looked ok,it had the metal propellers and they all looked fine.
So i now need help could it be the heater matrix i no this is a big job so i want to be sure its that before i start taking the dash out or could it be anything else?
The only other thing i noticed the car doing under load is pinking?well it sounds like pinking but i thought this could be the water pump making a noise but not sure
the cars temp guage gets to half way after about5 to 10 mins of the car running this is with the thermostat out and in so not really any difference there but it never goes above half way unless idling for about 5 mins in traffic but then the fan cuts in this is also with the thermostat out
Any help would be much appreciated
Thanks
Old Dec 17, 2008 | 04:55 PM
bagel's Avatar
Default RE: Heater coming out cold?
reverse flush the system you're heater core is prolly plugged.
TreeHuggin DirtLovin
Oct 19, 2011 03:57 PM
Tstubs
Jul 12, 2007 04:09 PM
dianmichele
Apr 9, 2007 12:27 AM
earthguy00
Mar 10, 2007 09:06 PM
