fan wont get on
Old Feb 1, 2009 | 11:11 AM
b52's Avatar
b52
Default fan wont get on
hi there....i have a 1994 golf A3...the radiator fan wont start, thus the car begins to overheat...can someone help me with this issue?? thanx
Old Feb 1, 2009 | 02:47 PM
dbaseballs's Avatar
Default RE: fan wont get on
check the fuses, the connections, and if all that checks out, get a multimeter (volt meter) and test the wires going to fan and see if its getting power
Old Feb 4, 2009 | 10:57 AM
freaKs@DubGear.com's Avatar
ORIGINAL: dbaseballs
x2
Then, could be the motor, or fan itself. The above troubleshooting steps will help detemine if you are getting power to the fan. If you are, then you know it IS the fan or motor itself. Order one, or grab one used, they should be much, especially used, or from a "U Pull It" Junkyard...
Post your findings / results, We're curious to how you make out.
Old Mar 2, 2009 | 02:19 PM
MaxMT's Avatar
Check this out this will help u diagnose the problem. It helped me find out that i needed to replace the radiator fan switch.
http://faculty.ccp.edu/faculty/dreed...work/index.htm
Max
Old Mar 2, 2009 | 05:25 PM
b52's Avatar
b52
Default ignition problem
thank u for ur help guys...it seems it was a blown fuse! as simple as that! i just replaced it, and voila! the fan worked normally! thanks again guys!
Odins Les Paul
Feb 9, 2010 08:21 PM
dar3000
Aug 20, 2009 11:24 AM
Dewald
Dec 15, 2008 11:33 PM
lightorch
May 6, 2006 01:43 AM
monkeyfist
Feb 3, 2005 01:00 AM
