brake/tail light problems!!!
Old Aug 6, 2009 | 09:31 PM
thejohncrawford's Avatar
Unhappy brake/tail light problems!!!
When I push on the brake pedal the right turn signal lights up (constant, not flashing) on the console. Likewise, when its on and i push the brake pedal, the turn signal turns off. Is this a ground problem or bad switch?
Any help would be appreciated.
Old Aug 10, 2009 | 06:58 AM
vw_tech30114's Avatar
Could be the ground wire or the switch or could be both. try fixing the ground wire and then see how it goes. if that doesnt work you will need to get a new switch.
huyuhy
Oct 8, 2011 03:44 AM
giddy1945
Jan 1, 2008 03:50 PM
beefstew202
Sep 3, 2007 09:54 AM
gfgls
Mar 12, 2007 02:10 AM
gbtr6
Feb 18, 2006 07:47 PM
