95 golf headlight/dash light problem
Old May 26, 2008 | 04:14 PM
freshmcgee's Avatar
Default 95 golf headlight/dash light problem
Recently, when ever I release the emergency brake, the headlights turn on, even if I have the switch on the dash in the 'off' position.When I actually turn the headlight switch into the on position, the dashboard lights do not turn on (which is incredibly helpful at night...). Also, the little green light above the headlightswitch does not turn on when I turn on the headlights.
Any help is appreciated.
Thanks in advance.
Old May 29, 2008 | 08:05 AM
heavenly_blade101's Avatar
Default RE: 95 golf headlight/dash light problem
Whats happening when you release the e-brake is the daytime running lights come on. so the problem is that either a fuse is gone for your headlights or the switch is bad. both of which would account for the headlights and dashlights not coming on when the switch is on. and yes your headlights are not comming on. the daytime running lights are the same brightness as your headlights.
Old May 29, 2008 | 08:44 AM
95RedGolf's Avatar
it is also possible that the bulbs in the dashboard are burnt out. i have the same car and when i bought it, the dashboard lights didn't come on. at first i thought the dashboard just didn't have lights. but anyway, it could be the fuse, or just burnt out bulbs. there are two of them but you have to take apart the entire dashboard. the dashboard lights, however should come on when you put the e-brake down unless mine is just all messed up because i never use the switch anymore because there is no point to it.
Old May 29, 2008 | 03:38 PM
freshmcgee's Avatar
Upon further inspection of this problem, I checked the fuses and the low beam fuse is intact. On the other hand, I can get the headlights and dashlights to come on, as long as I do not turn the key in to the on position. As soon as I turn the key past the initial position the headlights, dashlights, and light above the headlight switch all turn off.
Old May 29, 2008 | 08:26 PM
Jrailer's Avatar
might be head lt switch
i have had many of them do the same thing and it has always been fixed with new switch
Feb 4, 2011 05:31 AM
22inarow
Oct 22, 2010 06:01 PM
bens1088
Jun 19, 2010 11:17 AM
jetta can
Jan 3, 2007 02:31 PM
Angeline
Dec 3, 2006 03:21 PM
