guage questions
i just got my 95 cabrio.... lastnight i accidentally stalled it... when i went to restart it the speedo and tach wouldnt work... i played with it... turned the car off and on, but nothing... i got into it this morning and they worked... went to the grocery, and now they dont work again.... does anyone know wut this is and how i can fix it???????
I don't think it has anything to do with you stalling it.
It sounds more like a loose wire or contact, possibly in your ignition lock. How tight of a fit is the key? Is it snug, or does it feel like there is a lot of slack?
its not a bad connection or a bad ignition... it has to be a relay or something.... it only stops working under these conditions... if i drive to work its fine.... when i go home its fine... its only when stalled or when i try to go somehwere right after i park it.... i was just wondering if this problem was normal, and if someone knew where the relay was so i can replace it or somethin.....
FSU2001rx
Sep 25, 2006 01:06 AM
