Check engine code
Old Feb 2, 2010 | 12:09 AM
Greeneyezz714's Avatar
Default Check engine code
This car has been nothing but a nightmare but slowly I'm trying to get it up and running and to pass inspection. Trying to knock out check engine codes one by one.
I recently replaced the Mass Airflow Sensor, Coil Pack and gave it a full tune up. There is 1 check engine code still remaining P0441. From the research I found I changed the gas cap but the code is still there. Any information would be greatly appreciated! Thx
Old Aug 26, 2011 | 05:55 PM
Crusher201's Avatar
what did you ever find out about the p0441 code? i am having the same problem wih my 2006 tourereg.
Old Aug 30, 2011 | 03:21 AM
I replaced the charcoal canister and the pressure valve off the intake manifold. U also may want to consider a smoke test. It could be a hairpin leak in any of the evap hoses. Id do that first before spending money on replacing parts. Just a suggestion.
Good Luck & let me know how u make out.
Angela
Old Aug 31, 2011 | 06:50 AM
VAG Error Code: 16825
EOBD II Error Code: P0441
Fault Location:
Evaporative emission (EVAP) system - incorrect flow detected
Possible Cause:
Hose connection(s).
Intake leak.
Evaporative emission (EVAP) canister purge valve.
Old Aug 31, 2011 | 05:38 PM
Crusher201's Avatar
Thank you, i will let you know what i come up with.
01silver1.8T
Mar 31, 2009 09:34 AM
drioux
Apr 1, 2008 12:47 PM
magea
Oct 18, 2007 08:12 PM
magea
Oct 8, 2007 10:55 PM
braggvw
Aug 5, 2007 09:18 AM
