Check engine code
This car has been nothing but a nightmare but slowly I'm trying to get it up and running and to pass inspection. Trying to knock out check engine codes one by one.
I recently replaced the Mass Airflow Sensor, Coil Pack and gave it a full tune up. There is 1 check engine code still remaining P0441. From the research I found I changed the gas cap but the code is still there. Any information would be greatly appreciated! Thx |
what did you ever find out about the p0441 code? i am having the same problem wih my 2006 tourereg.
I replaced the charcoal canister and the pressure valve off the intake manifold. U also may want to consider a smoke test. It could be a hairpin leak in any of the evap hoses. Id do that first before spending money on replacing parts. Just a suggestion.
Good Luck & let me know how u make out. Angela |
VAG Error Code: 16825
EOBD II Error Code: P0441 Fault Location: Evaporative emission (EVAP) system - incorrect flow detected Possible Cause: Hose connection(s). Intake leak. Evaporative emission (EVAP) canister purge valve. As taken from my Free EOBD II Error Codes software |
Thank you, i will let you know what i come up with.
