abs sensors 99.5 Cabrio
Old Dec 31, 2011 | 12:44 PM
newomij's Avatar
Cool abs sensors 99.5 Cabrio
I need to replace, I think, the rear abs sensors. How do I determine if they are the female plug type or the male plug type. Just had the rear brakes and rotors replaced by a back yard mechanic. Everything seems to be working great but the ABS light and brake light stay on. He said he cleaned the exterior crud off the sensors but they would probably have to be replaced. I'm looking online for the parts and discover there are two types of rear sensors - female plug and/or male plug. Also, thinking of doing the replacements myself. Where can I find a good tutorial to accomplish this task?
Old Jan 1, 2012 | 08:04 AM
Just unplug the connector and you should see if its a male or female connector. Generally its the reluctor ring that get corroded so the sensor doesn't pick up the gaps correctly.
Happy New Year.
Old Jan 19, 2012 | 10:13 PM
newomij's Avatar
Default reluctor ring??
Might you be suggesting that the reluctor ring could be replaced independantly of the entire sensor???
Thanks for your answering my first inquiry.
Old Apr 28, 2020 | 11:09 AM
OldNavyGuy's Avatar
Since I just experienced the same thing, I would check the reluctor ring (ABS ring) before buying sensors.
Old Jan 24, 2021 | 12:28 PM
paityda's Avatar
Just unplug the connector and you should see if its a male or female connector. Generally its the reluctor ring that get corroded so the sensor doesn't pick up the gaps correctly. =>Speed Test
Old Apr 17, 2021 | 09:23 AM
stormshadow's Avatar
Dovetail
Jul 10, 2016 02:52 AM
huyuhy
Aug 26, 2011 03:46 AM
Jan 4, 2011 12:52 AM
euro_turbo
Jun 9, 2010 08:21 PM
Rob1uk
Nov 2, 2008 04:58 PM
