2002 Cabrio - Possible Fuel Pump Issue?
Old Nov 20, 2015 | 04:40 PM
donwozniak's Avatar
Question 2002 Cabrio - Possible Fuel Pump Issue?
On my 2002 Cabrio, I noticed a high pitched whining noise under the rear of the car when it is idling. I suspect the fuel pump is going bad. If I just turn the key on without starting, I can hear the fuel pump turn on for a couple seconds but I'm not sure if it is the same sound. The car is running and performance is not affected yet. I would like to resolve the issue before a breakdown. If anyone could offer some advice and experience with this problem it will be greatly appreciated. Thanks in advance!
Don
Old Nov 21, 2015 | 06:32 AM
The fuel pump will switch on when you turn the key on to prime the system. It depends if you think its an excessive whine? You need to replace the fuel pump.
Old Nov 22, 2015 | 08:37 AM
donwozniak's Avatar
Thanks Keith! I ordered a new fuel pump assembly. Looks like It's not too difficult to install but I could use some guidance. I really haven't looked at it yet but I assume I need to remove the fuel tank to do it. Can you share some expertise on this procedure? Thanks!
Don
2002 Cabrio 2.0 Automatic
Old Nov 22, 2015 | 03:40 PM
Old Nov 22, 2015 | 06:11 PM
donwozniak's Avatar
Keith ... Thanks once again for a rapid reply! I looked at the videos and changing out the fuel pump assembly seems pretty straight forward. I should have the pump I ordered in a couple days. I will report back with my results or request further advice soon. Thanks!
Don
2002 VW Cabrio 2.0 Automatic
kallas0425
Aug 26, 2015 12:18 AM
SouthernGent
Dec 16, 2014 07:46 PM
ChrisBrooks
Dec 21, 2013 12:44 AM
Bethe
Oct 9, 2011 07:09 PM
Vr6Monster
Mar 1, 2011 10:23 PM
