interference motor??
Old May 2, 2017 | 10:22 PM
torinoman's Avatar
Default interference motor??
Anyone out there know if the 2003 2.0 L is an interference motor or not ? Timing belt jumped a few teeth,,
Old May 3, 2017 | 08:25 AM
Yes it is.
Check for Engine Damage:
CAUTION: This engine has been identified as an INTERFERENCE engine in which the possibility of valve to piston damage in the event of a timing belt failure is MOST LIKELY to occur. A compression check of all cylinders should be performed before removing the cylinder head(s).
gmohamedi
Sep 30, 2010 02:23 AM
daiz
Oct 11, 2009 11:01 AM
tnonk17
Jun 22, 2007 05:37 PM
bpetry
Mar 23, 2007 01:14 AM
emagdnim
Aug 24, 2006 07:17 PM
